Hard to get into first sometimes?
RE: Hard to get into first sometimes?
ok then...do what i said about cable/fork tightness....clutch releasing towards floorboard or later?....<like way later?..
sounds like an easy fix...>cable
ORIGINAL: grabbem88
synchro's ussually,and i'm being light on this,but it would give you noise,grind scratch..that sort of thing...
no problem on helping out..iv'e been there so i have a little knowledge of what goes on
+1when youre slowing down you should pull it toward 2nd and then go up. id say you check the cable play too if anything. but its prolly OK. youre just wiggin man!
ORIGINAL: grabbem88
so if you are coasting you can down shift into first?....complete stop notchy?...
well i'll say what iv'e learned...i can not ever put my car into first gear while coasting more than 10mph..
check your clutch fork..see how much play (shouldn't be much) on cable from fork...
your tranny is worn out...
ORIGINAL: ikeybmg
ORIGINAL: grabbem88
Matt's 95 Stang
10-05-2015 07:16 AM
