Tranny Vibrating in OD
Old 05-12-2006, 01:03 AM
5.0 MPG
5.0 MPG's Avatar
Default Tranny Vibrating in OD
I tightened my TV cable and now when I going above 60 and let off the gas pedal the tranny vibrates pretty bad? When I loosen the cable the tranny has too much play and smacks around. Should I thighten it more or loosen it?
5.0 MPG is offline
Old 05-12-2006, 01:14 AM
5.0 MPG
5.0 MPG's Avatar
Default RE: Tranny Vibrating in OD
bump
5.0 MPG is offline
Old 05-12-2006, 01:41 AM
Tims 88GT
Tims 88GT's Avatar
maybe loosen it a lil
Tims 88GT is offline
Old 05-12-2006, 01:53 AM
5.0shelby
5.0shelby's Avatar
i have the same problem but i dont know how to fix it. Before you tightened it when u took off did the drive shaft rattle?
5.0shelby is offline
Old 05-12-2006, 01:56 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
have u checked the driveshaft?
rmodel65 is offline
Old 05-12-2006, 02:10 AM
capnacee
capnacee's Avatar
MINE DID THAT A WHILE BACK,AND IT ENDED UP BEING THE DRIVE SHAFT. ENDED UP PUTTING ALUM. D/SHAFT IN AND ALL IS WELL.
capnacee is offline
Old 05-12-2006, 02:22 AM
5.0 MPG
5.0 MPG's Avatar
Its always vibrated. Now that you guys mention it, it probaly is the drive shaft. Anyway I tightened it and its better. How can I confirm if it is the drives shaft?
5.0 MPG is offline
Old 05-12-2006, 02:28 AM
ZoSo15
ZoSo15's Avatar
have someone hold on underneath the car when your on the highway
ZoSo15 is offline
Old 05-12-2006, 02:35 AM
5.0 MPG
5.0 MPG's Avatar
will he need a creaper?
5.0 MPG is offline
Old 05-12-2006, 02:38 AM
capnacee
capnacee's Avatar
IF YOU TIGHTENED THE CABLE, AND IT STOPPED VIBRATING IT SHOULDNT BE THE D/SHAFT. BUT IF IT STILL VIBRATES AROUND40- 60. PROBLY IS THE D/SHAFT. COULD ALSO BE U-JOINTS...
capnacee is offline
Quick Reply: Tranny Vibrating in OD
