MT ET Drag radial question
RE: MT ET Drag radial question
an 8.8 rearend is almost as stong as a 9 inch
your not going to hurt it with a stock motor
even spraying it 200, it will hold up, as long as your shifting habbits are ok you wont tear the t5 up for a while
dont waste your money on big axles unless you have a race motor
i recomend 373 gears with some small et streets no slicks unless your gonna spray it
so it wont bog as bad, it might even bog on et streets
maybe it will haze the tires half a car legnth and keep the rpms up but i doubt it
One last question guys I went to go order the MT ET Street radials I noticed they also make MT drag radials, is there a huge difference between traction from a MT street radial to drag radial, Jegs.com says the Street is R2 compund and the drag radials are R1, which will give me the most traction for my money?
Also what are the specs on these rims on my stang? Are they oem rims? Will the 235 fit w/o a problem?
[IMG]local://upfiles/36593/C9B7D6FA80C14F938A009ABC065953A8.jpg[/IMG]
[IMG]local://upfiles/36593/1CF43358118B4F58B3A1FAAC6696A4D4.jpg[/IMG]
The drag ets are definitly going to give you better traction. If your not putting serious power down then the et streets will be fine. My car is almost stock and with et streets at 30 psi I can't spin the tires unless I'm powerbraking my car.
Also those are stock rims, 235's will go on no problem.
ORIGINAL: ZachW04Stang
i have m/t et streets the 235/60 15 and i get good traction with them on wet or dry road been rainin here for 3 days now and car handles better with the ets then it did regular radials i have lauched from stop lights at 1700 rpms in the rain and no spin only way i break them loose in rain or dry is taking it up to at least 2g
yea Zach let me try his out, they bite good. u dont need more than a 26inch tire with 3.73's and under 300hp.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
