ODB I codes
Old 04-03-2004, 05:24 PM
tchamber
tchamber's Avatar
Default ODB I codes
Hey all, I just pulled these codes from my 95GT:
181, 189
181 means "Adaptive fuel limit reached at part throttle, right side" but what do I do to fix that?
189 means "Adaptive fuel limit reached, left side." Same question. Is this an O2 sensor problem, or maybe TPS?
TIA
-Tye
tchamber is offline
Old 04-03-2004, 05:31 PM
Milky
Milky's Avatar
Default RE: ODB I codes
I think your putting too much fuel into the mixture, just a guess
Milky is offline
Old 04-03-2004, 06:18 PM
tchamber
tchamber's Avatar
That is the obvious first idea, but what do I do to fix it?
tchamber is offline
Old 04-03-2004, 07:13 PM
Milky
Milky's Avatar
Your 02 sensors maintain your mixture, so Id start there..
Milky is offline
Old 04-05-2004, 05:42 AM
tchamber
tchamber's Avatar
I dont know how to check if it's working properly. Is there a voltage I should check for?
tchamber is offline
Old 04-05-2004, 06:16 AM
MelloYello
MelloYello's Avatar
It could be your MAF, CMP, or PCM sensors also.... theres testing you can do with a DVOM.... If you have a book to your car itll tell you the voltage it needs to be at.... You can disconnect your O2's and measure the resisitance between power and ground terminals of the sensor... 6 ohms @ 68 degrees means in good condition....
Connect the sensors and w/ the car running you can use a DVOM again and measure the voltage's between the terminals of the sensor connector... Im not sure what the proper volt readigs are for when the car is warming up.... I know when the car is off itll read 0 volts, and I think when the car is warm it should be about .5V..... You need something that lists the tables for you so you can match up the volt readings....
MelloYello is offline
Old 04-06-2004, 04:21 AM
tchamber
tchamber's Avatar
Thanks man, I will look into it. Although I am getting a GSX-R750 really soon here, taking it out again tomorrow, so it might be awhile before I get around to the Stang. My brother and dad used to give me a hard time about not having a bike. I said I wasn't ready to lose interest in the Mustang, and here I am, losing interest in the Stang because of a bike. Man that bike is fast, goes 167MPH, 0-60 in 2.6, 1/4th in 10.7.
tchamber is offline
BOB ROME
07-26-2023 01:54 PM
mrtrodonet
09-19-2020 03:12 PM
lincolnshibuya
12-08-2015 04:37 PM
Dathan
10-05-2015 05:52 AM
mustangheaven
09-29-2015 11:00 AM
Quick Reply: ODB I codes
