ok i drive a 95 mustang gt. when ever you open the door is the overhead light suspose to turn on. if so why doesnt mine. do i need to change the fuse. the only other electronic that doesnt work on my car is the clock. do they use the same fuse or is it a wireing problem? if anyone knows it would be awesome.
try pulling the assembly out and check if the bulb is blown. When I got my car they didnt work and I pulled all the crap out and all the wires were disconnected. [sm=badidea.gif]
could be a fuse but which one? i dont know which fuse the light runs off. id need the electric schematic. Could be buld too. change it out. U have sunroof? water may have shorted its cicuit?
Yes. I'm not sure about the SN95 but the Fox's assembly has two positions. Try taking a voltage tester and see if the wires up there are getting power. That will give you a good place to start.
