PULLED CODES QUESTION....
I have a 92' GT 5.0 and I just bought a code puller from kragen and pulled 44r "Thermactor air sustem fault" or "thermactor air system inoperable-right side" and i also pulled a 94r "air diverter solenoid circuit fault" or "thermactor air system inoperable-left side" what the hell is a Thermactor air system and why is my car's system inop. Could that be why i cant pass CA emmisions???
RE: PULLED CODES QUESTION....
Yep....that could be the reason why it's not passing emission testing. The thermactor system pumps air into the exhaust through the heads or exhaust pipes. Codes 44 & 94 means it is not functional due to electrical problems, vacuum issues or pipes could be clogged. To check the system description and the functional tests to id what might be the cause, check the information at http://www.autozone.com/servlet/UiBr...3d80194a36.jsp Hope this helps.
check this out ,im having the same problem with my car.http://forums.stangnet.com/showthrea...ght=thermactor
