Wiring Problem
RE: Wiring Problem
no but you can add a temp sensor. just rig it to a switch also cause on my 69 my fan will stay running on a hot day. So i have to readjust it. it's easier to to just flip off a switch if your sensor starts to act up on you
RE: Wiring Problem
Its is a used setup that worked on a different car here is what i did I installed the radiator and fan, they were together when i bought it. Pluged in BCG+ there was already a wire assembly i put the possiteve wire to my starter selinoid the groing to an engine bay screw and there is a caped off set of three wires and the a/c connection plug i left out since i do not have ac any longer. I havent got the fan to work. Are my wires connected correctly?
zanemoseley
09-06-2015 12:58 PM
