1994 5.0 EGR
1994 5.0 EGR
Im new to the forum so bear with me.I just put a 5.0 crate motor in a 94 GT and its vortech supercharged and trick flow intake etc.My question is.What kinda problems will I incurr by unhooking and blocking off the EGR valve.WAAAYYY to much heat goin in the intake and we all know what heat takes away from superchargers.I appreciate any input.THX
RE: 1994 5.0 EGR
ORIGINAL: ZoSo15
the exhaust gasses that are recirculated actually cool the intake charge. if you removed the egr, your intake charge temperature would skyrocket causing your motor to ping.
Are you kidding?
RE: 1994 5.0 EGR
The EGR system is used to lower oxides of nitrogen emission levels caused by high combustion temperatures. the EGR recirculates a small amount of exhaust gases into the intake manifold. the additional mixture lowers the temperature of combustion thereby reducing the formation of NOx compounds.
Too little or no EGR flow allows combustion temperatures to get too high during acceleration and load conditions. this can cause detonation, engine overheating or emission test failure.
