Are These Gears Junk?
RE: Are These Gears Junk?
yea, im doing them in my auto shop class. my auto teacher isnt your typical idiot teacher, so i trust him on the install. hes going to show me what to do, and im going to do it. i figured it would be a great thing to learn early, and i am only 17.
ORIGINAL: RawGtPower
im sure theyll be fine bro. You should have no worries. Good luck with the install. Are you installing them yourself?
I got lucky on mine the shims that where already in the rear end put me almost perfect on the pinion depth and basklash. I am only like 1-2 thousandths away from the center of tolerance measurements. From what I have discovered most not all but most 3.73 gearsets usually use the same shims as 2.73.
http://www.angelfire.com/theforce/5o...5ohtech001.htm this site helped out alot on mine good luck.
