Poly motor mounts?
Old 05-16-2006, 10:27 PM
93foxgt
93foxgt's Avatar
Default Poly motor mounts?
Can anyone suggest a good new motor mount that I should get for my 93 GT? I think that's it's time to replace mine.
What brands are the best for motor mounts, or are they pretty generic and should I just go with Mac or some ebay brand or put out a little more and notice a difference? Also, how long do urethane mounts last on average?
93foxgt is offline
Old 05-16-2006, 10:29 PM
FiveLiterRiceEater
FiveLiterRiceEater's Avatar
Default RE: Poly motor mounts?
energy suspension.
if you go with poly motor mounts dont use a poly trans mount, youll start breaking stuff.
FiveLiterRiceEater is offline
Old 05-16-2006, 10:47 PM
silver91gt
silver91gt's Avatar
energy suspension.
why do you think it will break something if you use both poly engine mounts and tranny mounts?
I have had mine on there for a couple of years, and nothing has broke yet.
and they will outlast the rest of the car.
silver91gt is offline
Old 05-16-2006, 11:21 PM
93foxgt
93foxgt's Avatar
Thanks guys.
So Poly is the best you can both recommend? What about delrin? Do they make Delrin mounts or only suspension bushings?
93foxgt is offline
Old 05-16-2006, 11:29 PM
brutal_gt
brutal_gt's Avatar
just did mine, i went with energy suspensions. my were pretty bad so when i changed them it felt like i added a strut bar up front.
[IMG]local://upfiles/4191/3EF9546183304D628EC8E338E8927117.jpg[/IMG]
[IMG]local://upfiles/4191/2017E78464444C2ABBCCDFD8A4971F12.jpg[/IMG]
brutal_gt is offline
Old 05-16-2006, 11:30 PM
brutal_gt
brutal_gt's Avatar
some more...
[IMG]local://upfiles/4191/85F1361A8A3C4A4B8313357FE7887E1D.jpg[/IMG]
[IMG]local://upfiles/4191/3BC0664C2E2E4301BBC5A8E14E926739.jpg[/IMG]
Old 05-16-2006, 11:45 PM
93foxgt
93foxgt's Avatar
Pretty straight forward install right? Just put a 2x4 under the oil pan, undo the 2 bolts per bushing, then put a 2x4 under the oil pan and lift the engine, right?
93foxgt is offline
Old 05-16-2006, 11:49 PM
FiveLiterRiceEater
sorry for the vauge "break stuff" statement.
My buddy ran poly mounts for the engine and trans with a tremec 3550. this was a drag racing application also. he ended up breaking the tremec 3 different times. the OEM bushings let the trans and engine have a little bit of give under high loads, the poly bushings dont. so the weakest driveline link ends up breaking. this case being the input and output shafts on a tremec 3550.
if you arent racing and launching at like 4500+ then you'll probably be fine. In my opinion, i wouldnt reccomend using a poly trans mount. OEM should be fine.
Old 05-17-2006, 12:02 AM
brutal_gt
brutal_gt's Avatar
ORIGINAL: FiveLiterRiceEater
im gonna have to disagree on the poly's not giving. solid motor mounts dont give, poly's do just not as much as stock. there's also the added benefit on material longevity.
Old 05-17-2006, 12:05 AM
ZachW04Stang
ZachW04Stang's Avatar
Drag racers use solid motor and trans mounts and don't break trans because of that. It sounds like your buddy had different problems. I run moroso solid motor mounts and prothane polyurathane trans mount and I don't have any problems.
ZachW04Stang is offline
Quick Reply: Poly motor mounts?
