Clutch chatter. Is there a such thing?
Old 05-20-2006, 08:43 PM
nyyankee
nyyankee's Avatar
Default Clutch chatter. Is there a such thing?
I started my 93 stang this morning. It was quit outside and I heard it every once in a while, while I had my hand on the stick some "chatter" or "ratteling". It did not last but more than 1-2 seconds every once in a while but I heard it. I crawled under the car like maybe the exhaust was vibrating against the underbody. But I figured out when I step on the clutch it does not happen. I just purchased the car and I know the previous person changed the clutch because it is extremely hard to step on. I get leg cramps. Nothing compared to my stock 93 Cobra, she's like butter. Is it possible to have some clutch chatter?
nyyankee is offline
Old 05-20-2006, 09:28 PM
OnyxCobra
OnyxCobra's Avatar
Default RE: Clutch chatter. Is there a such thing?
there is such a thing as clutch chatter, its usually when the clutch is messed up or high performance...
OnyxCobra is offline
Old 05-20-2006, 09:32 PM
AdderMk2
Banned
AdderMk2's Avatar
It is possible, pucked clutches do it ALL the time... it really depends on what kind of clutch is in your car... most of the time a OEM style clutch will only chatter when its on its way out
AdderMk2 is offline
Old 05-20-2006, 11:33 PM
nyyankee
nyyankee's Avatar
Well I think it has to be High Performance. He changed the gears and I guess a clutch because the clutch pedal is extremely hard to depress.
ORIGINAL: OnyxCobra
nyyankee is offline
Old 05-20-2006, 11:41 PM
93BlackNotch
93BlackNotch's Avatar
ORIGINAL: nyyankee
ORIGINAL: OnyxCobra
The pedal being hard to push has nothing to do with the age of the clutch... You might want to invest in an adjustable clutch quadrant and a new cable...
93BlackNotch is offline
Old 05-22-2006, 12:20 AM
nyyankee
nyyankee's Avatar
Can you explain an adjustable clutch quadrant and what it does. And if I replace this and a cable would that make the clutch softer. Why do people always say when you get a performance clutch the pedal is always harder?Thanks for any info?
nyyankee is offline
AmericanMuscle4.6GT
11-10-2015 02:06 PM
stangin1996gt
09-21-2015 11:01 AM
ccdguy
09-19-2015 05:20 PM
MasterLanMan
09-13-2015 08:21 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Quick Reply: Clutch chatter. Is there a such thing?
