Rear wheel hub
Old 05-21-2006, 02:26 PM
seight311
seight311's Avatar
Default Rear wheel hub
Need help here guys. Long story as to why I need this but. I need a driver's side rear wheel hub. When I went to parts store they said it's not in there computer and he wasn't exactly sure why other than we dont carry anything for it. And a friend said if they dont carry it than that may man I will have to replace the entire rear end. I don't believe that, so anyone know where i can get one, or have the part number for it?
seight311 is offline
Old 05-21-2006, 02:44 PM
86HOGT
86HOGT's Avatar
Default RE: Rear wheel hub
What the hell are you talking about? There's no "hub" in the rear end. There's a bearing and seal if that's what you're talking about.
86HOGT is offline
Old 05-21-2006, 03:06 PM
5.0stanger
5.0stanger's Avatar
Maybe an axle?
5.0stanger is offline
Old 05-21-2006, 03:15 PM
seight311
seight311's Avatar
yeah my friend said the axle. Bearing and a seal? Im talking the bolts that hold my wheel onto my car, they are currently bent and 2 snapped. What part do i need to fix this problem.
Old 05-21-2006, 03:17 PM
5.0stanger
5.0stanger's Avatar
wheel stud kit
Old 05-21-2006, 03:23 PM
primetime5.0
primetime5.0's Avatar
you may want to check and see if the whole axle isnt bent, no sence in replacing studs when the whole thing is trashed
primetime5.0 is offline
Old 05-21-2006, 03:46 PM
seight311
seight311's Avatar
Yeah first priority is getting it back to my house to lift it up and check it out. But it looks to me a a few guys that helped me out that it's just the stud thats fried who knows though could be alot more.
Old 05-21-2006, 03:47 PM
5.0stanger
5.0stanger's Avatar
good luck
Old 05-21-2006, 04:11 PM
seight311
seight311's Avatar
I mean rotor could be bent, axle could be bent. Im just glad things ended up how they did the tire stayed inside the wheel well and from where my bolts flew out to where i pulled over and stoped was only 75 feet, but I had about 15 cars in front of me and 20 behind on a one-way 4-lane road. could have been alot worse. Ohh and if this makes no sense to you basically I thik someone loosend my nuts, because the nigh before this happened I lost a center cap on the same wheel and im thinking it fell of because someone that did it didn't snap it back into place completly.
Old 05-23-2006, 10:20 PM
seight311
seight311's Avatar
Got it, it was cheap just needed new studs, and about 4 hours to get my rotor off. Thanks for the help though guys.
Quick Reply: Rear wheel hub
