Mass Airflow ?
RE: Mass Airflow ?
where do you get the kit and what is the difference between Speed density and Maf system.... what sets them apart and if you want to upgrade your injectors on speed density how does that process work ... thank you
RE: Mass Airflow ?
you don't upgrade injectors with speed density. you don't upgrade ANYTHING with speed density, unless you have a tuner or want to pay someone to tune it, period. mass air will allow for some changes, including heads, cams, and intakes without tuning issues. be careful about increasing injectors with mass air, though. you will need a properly calibrated mass ait meter. even then, the further you go from stock, the less accurate it will be.
read this site, it will show you the way...
http://fordfuelinjection.com/
