Mass Airflow ?
Old 05-22-2006, 02:18 AM
Lysawy
Lysawy's Avatar
Default Mass Airflow ?
Whats going on guys ... just got a 88 GT 5.0 and there is no maf sensor and i don't even see the harness for it .....
is it possible that the car doesn't have one...
Second problem is that its idle is high around 1000 rpm and timing feels off pulls strong bottom end 1000-2800 then it pings ....
by the way im new to mustangs so be patient with my lack of knowledge about them...
thanks
Lysawy is offline
Old 05-22-2006, 02:32 AM
primetime5.0
primetime5.0's Avatar
Default RE: Mass Airflow ?
only cali 88 cars had mass air, otherwise its speed density
primetime5.0 is offline
Old 05-22-2006, 02:35 AM
Lysawy
Lysawy's Avatar
Ok that clears it up ... let me check the timing and look for any vaccum leaks.....
also im gonna do a compression test what is the number im looking for
steady across 150 psi difference between cyl..?
Lysawy is offline
Old 05-22-2006, 02:36 AM
primetime5.0
check the tps and set to .98-.99 if its off
Old 05-22-2006, 02:39 AM
FiveLiterRiceEater
FiveLiterRiceEater's Avatar
so 89 was the first year for mass air?
FiveLiterRiceEater is offline
Old 05-22-2006, 02:40 AM
Lysawy
Lysawy's Avatar
ok thanks , well let me do the compression test and see what a gotta do....
run it stock or go for trick flow heads,cams,lower,upper intake no ac , no smog pump ....
and buch of other things
Lysawy is offline
Old 05-22-2006, 02:46 AM
lookinforastang
I ♥ Acer
lookinforastang's Avatar
ORIGINAL: FiveLiterRiceEater
yes
lookinforastang is offline
Old 05-22-2006, 04:13 AM
88canadianstang
88canadianstang's Avatar
ORIGINAL: Lysawy
thanks
Welcome here.....I don't have mass air either 1988 as well. This isn't a problem at all though, don't worry about it, I've got some decent mods on my car and the forced air is doing just fine. You only might consider mass air if you get into heads/intake/blower etc. And the idle problem, Very common to mustangs.[:'(]
88canadianstang is offline
Old 05-22-2006, 08:18 PM
gmoney
gmoney's Avatar
I have an 88 GT and even though it ran fine with speed density, after I converted to MAF, throttle response was drastically better, and the car had more pull to it, so I recommend converting, its an easy thing to do yourself.
gmoney is offline
Old 05-22-2006, 08:22 PM
Lysawy
Lysawy's Avatar
ORIGINAL: gmoney
How would i do that...
Lysawy is offline
Quick Reply: Mass Airflow ?
