91 w/AOD trouble
Old 05-22-2006, 10:51 AM
brpelton
brpelton's Avatar
Default 91 w/AOD trouble
I need some advice, my 91 LX W/AOD has been acting up. It upshifts rapidly, and when in overdrive the trans seems to slip, a friend told me to ajust the bands, another told me to check the modulator. I am not that experienced with transmissions, can anyone point me in the right direction? Barry
brpelton is offline
Old 05-22-2006, 11:09 AM
tomasharvey
tomasharvey's Avatar
Default RE: 91 w/AOD trouble
If it slips in OD and this just started happening I would suspect that the OD band is going out. WHen an AOD is driven in OD all the time it constantley shifts from 3 to OD during normal street driving. I would say it's rebuild time. I would also suggest if you do get it rebuilt, don't drive it in OD unless you are on the highway due to OD band wear...in other words leave it in D.
tomasharvey is offline
Old 05-22-2006, 11:10 AM
91 5.0lx aod
91 5.0lx aod's Avatar
if you have a shop you trust i would have him look at it. if its starting to slip you would be better off fixing it now before it grenades.
91 5.0lx aod is offline
Old 05-22-2006, 11:16 AM
P Zero
P Zero's Avatar
First things first, check the fluid level. When checking it, the car has to be running. I bet its low. The AOD in my ranger does the same thing. It just wants to get itself into the highest gear possible. My trans has a leak on the front pump seal so its hard for me to keep fluid in her. And if it is full (which I highly doubt), change the fluid and filter. BTW, normal fluid service intervals should be no more than 20k miles. And if all that doesnt work and you need to get the trans rebuilt, make sure you get some trans line cooler flush, itll remove the metal shavings and other dirt particles from the cooler so you dont "infect" the new trans with old debris.
-P.
<CHECK THE FLUID LEVEL>
P Zero is offline
Old 05-24-2006, 02:45 PM
brpelton
brpelton's Avatar
looks like my trans is shot, thanks for the advice.
brpelton is offline
Nurdyguy
02-18-2024 07:58 PM
CS2007
06-25-2019 09:45 PM
msavoia23
12
07-07-2018 12:08 PM
chrisdbassplayer
10-13-2015 06:53 PM
TorinoCobra070
SVT Forums
09-18-2015 10:34 AM
Quick Reply: 91 w/AOD trouble
