NEED HELP QUICK ... Ill have it in shop thursday
RE: NEED HELP QUICK ... Ill have it in shop thursday
im not syaing i need 50poudns of fuel pressure its just what it has been runin i really didnt now what was good for it.. but umm its got a f303 cam like a .530 lift i belive umm steel crank forged pistons... what more do u need?
was the tps set?
is the maf calibrated for the 24's?
try setting the fuel at 35 psi
set timing at 10 to start
because we need to back up to get it going in the right direction
ok that sounds good yes every has been calibrated for 24's .. but also i now 10 is the general area to start umm my boss at work askd me what was the timing for liek everything liek teh distributer and the ignition timing.. he said liek 35 or somthin i really didnt now what he ment ...
bumping it down to 35psi will give me better gas milage wont it? cuz i use this car every day..
better mileage...maybe do to rich condition but that's it turning down the fuel pressure won't net you any now setting the time to like 6 will..as for the 35 degrees he is more likely talking about total timing advance at say 2k
ok ya thats what he was talking about total timing.. so what should that eb set at to start adjusting th ignition timing?.. and i got my sig workn finally.. but should it be at like 18 and then my ignition at 10 to start of with.. im sure it can be bumpd up a lil from stock right?
bradleyb
11-27-2015 07:50 PM
10-05-2015 07:40 AM
