thermostat?
#21
RE: thermostat?
the mr gasket stat opens right at the temp also the ofice is bigger for more flow and it is flow balance,it also have a small hole in it to let water trickle out so tou wouldn't have the air pocket thing fords are famous for..the 180 is perfect for winter and summer also if when you change your rad,going to a 3 core will make a hugh difference more if you have a automatic for whick you should have a trans cooler on it
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
