BBK header / x pipe fit?
Old 05-24-2006, 04:50 AM
88NOTCH
88NOTCH's Avatar
Default BBK header / x pipe fit?
i spent all day yesterday battling with my new bbk unequal length shortie headers. the car has a offroad x pipe on it and once the headers are torqued down, the x pipe is off by about 1/2". i ended up dropping the whole x pipe down and torqued down the headers. i reinstalled the mid pipe but when i tried to tighten the pipe to the headers one of the sides leaks. i tightened one header to the mid pipe completely then went to the other one and tried to tighten it (probably a mistake). but the pipe doest want to sit perfectly on the other header. suggestions?
88NOTCH is offline
Old 05-24-2006, 04:52 AM
Goosepoop302
Goosepoop302's Avatar
Default RE: BBK header / x pipe fit?
Crowbar
also i think i can buy or make a gasket for the collecter, i need to get one
Goosepoop302 is offline
Old 05-24-2006, 09:43 AM
Boss_Hotrod
Boss_Hotrod's Avatar
Check and make sure there is no visable mistakes on the headers (mainly the flange). If there doesnt seem to be one try a different x-pipe. We put BBK Longtubes on our 93 and the header flange was bent nocking the h-pipe off by .5". A new header fixed our problem.
Boss_Hotrod is offline
Old 05-24-2006, 10:03 AM
7upedition
7upedition's Avatar
^^prolly the header but when installing an exhaust system the rule of thumb is to torque the headers down and tighten the system from the tailpipes forward evenly adjusting it... try getting all bolts started and then tighten them all lil bit at a time (evenly)
7upedition is offline
Old 05-24-2006, 10:43 AM
black89gt
black89gt's Avatar
7upedition Date 5/24/2006 7:03:01 AM
+1
black89gt is offline
Old 05-24-2006, 02:20 PM
gspfunk
gspfunk's Avatar
My stock H didn't match up w/ my FRPP headers exactly either... I pulled and got it close enough I could bolt it up. Then I just made sure it closed up flush as I tightened it. Just needs some elbow grease.......
gspfunk is offline
Jb145700
08-21-2022 06:37 AM
SSG Steggy
3.7L V6 Technical Discussions
11-05-2015 03:09 PM
Luke9222
10-22-2015 11:55 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Luke9222
09-04-2015 06:46 AM
Quick Reply: BBK header / x pipe fit?
