loud clunk from the rear end
RE: loud clunk from the rear end
right above axle looks like a block of rubber...function?...axle to frame prevention helps with launching...if you wheel hop it's supposed to be a bandaid.from damage.
ORIGINAL: ikeybmg
my rear sway bar broke on one side and it beat against the frame when i hit bumps. did you check that also? just guessing here
ORIGINAL: FiveLiterRiceEater
do you hear it when you put it in gear? or whenever you're driving? accel, decel?
That may be whats wrong with mine too. only does it on big bumps though. & there is a loud clank when i shift from reverse to 1st or 2nd & actually move. I thought it might have been the gears.
Dragonus18
09-09-2015 01:21 AM
09-01-2015 08:16 PM
