fan too loud
Old 05-26-2006, 06:17 PM
anthonydalrymple
anthonydalrymple's Avatar
Default RE: fan too loud
ORIGINAL: SmokeYoV8
ok so i tried spinning the fan and it doesnt spin freely...it barely moves and when it does move it moves the belt and spins other pullies with it so im guessin thats not spinning freely and i guess my fan clutch is good...the fan is very loud when i rev..sounds liek a shoprite truck lol....... there is plenty of clearance so its not touching anything...any ideas?
It's bad! Replace the fan clutch.
anthonydalrymple is offline
Old 05-26-2006, 06:18 PM
88BlueGT
88BlueGT's Avatar
Or it could just be the stock fan..... the stock fans on 5.0's are very loud.
88BlueGT is offline
g2_5point0
g2_5point0's Avatar
from what others have said, it's NOT supposed to spin freely. If it did, then it'd be a bad fan clutch
g2_5point0 is offline
Old 05-26-2006, 06:20 PM
5.0 MPG
5.0 MPG's Avatar
Jack up front and back license plates, remove car, insert another mustang, attach license plates..........problem solved!
5.0 MPG is offline
Old 05-26-2006, 06:39 PM
collincastaneda
collincastaneda's Avatar
ORIGINAL: 5.0 MPG
LOL!!!
collincastaneda is offline
Old 05-26-2006, 08:47 PM
r.barn
r.barn's Avatar
tell'n you it's the fan clutch, thats what they sound like when they go bad.
mine got super quite after i replaced it. Nite and day now, thought I had
an exhaust or combustion leak the longest time.
https://mustangforums.com/m_1348884/tm.htm
r.barn is offline
Old 05-26-2006, 09:44 PM
silver91gt
silver91gt's Avatar
if the pulleys spin when you spin the fan by the blades, then your fan clutch is seized.
it should be able to spin without spinning the pulleys, but it should take some effort to spin it.
silver91gt is offline
Old 05-26-2006, 10:58 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: SmokeYoV8
Do you have a fan clutch or a flex fan? If a flex fan there is no clutch and your description is normal. If you have a fan clutch set-up, then it's bad.
PRO50SC is offline
Old 05-27-2006, 12:20 AM
76stangalang87
76stangalang87's Avatar
Im just replacing mine with a $60 advance auto parts fan my buddy did it he hooked a realy to his ignition. THe relay wiring and fan was like $70 and it would be less drag on accesories
76stangalang87 is offline
BOB ROME
07-26-2023 01:54 PM
PaulH2
20
01-31-2016 09:48 AM
KingRando
10-02-2015 08:06 AM
MustangV6P
09-28-2015 11:00 PM
09-25-2015 09:06 AM
Quick Reply: fan too loud
