broken bolt blues
Old 05-26-2006, 07:00 PM
elusive1
elusive1's Avatar
Default broken bolt blues
i was attempting to install my h-pipe today and broke off one of the studs/bolts inside of the flange on the bottom of one of the header pipes. we cut it off on both sides and tried drilling out the center.. but it was taking forever with our drill bits. so then we tried using an easy-out to extract it and the easy out broke off inside of the hole we had drilled lol. oh yeah, that was even after heating it up with a blow torch to the point where it was red. anyone have any other suggestions? or should i just take it to an exhaust shop to have them do their magic?
see.. this is why NOTHING is ever easy.. NOTHING.. something always goes wrong.
elusive1 is offline
Old 05-26-2006, 07:03 PM
myshifter
I ♥ Acer
myshifter's Avatar
Default RE: broken bolt blues
if you didnt heat the stud BEFORE removing, only blame yourself for breaking it. BUT an exhaust shop isnt going to do anything you cant do. Go to the hardware store get a case hardened or titanium bit the size you need and drill. I receive satisfaction after accomplishing something that goes wrong.
myshifter is offline
Old 05-26-2006, 07:05 PM
P Zero
P Zero's Avatar
Yep drill it out then just get a 2.5 or 3" bolt, and nut n bolt it together.
-P.
P Zero is offline
Old 05-26-2006, 11:14 PM
tinman
tinman's Avatar
Bolt should be a grade 8. Decent hardware store should have it.........
tinman is offline
GimpyHSHS
19
12-19-2023 01:12 PM
baddog671
07-26-2016 01:20 PM
Stone629
The Racers Bench
66
06-02-2016 09:52 PM
winner99
10-01-2015 01:06 PM
09-25-2015 06:58 PM
Quick Reply: broken bolt blues
