Starting Problem HELP!!
ok i have an 89 stang 5.0, cobra upper/ lower intake, 65 mm. tb, cold air indiction, E-303 cam, etc. i just recently removed my smog pump and also installed a bbk fuel press. regulator. i have it set at 40psi with the vaccum tube diconnected. (i have stock injuectors) after i did these 2 things ive noticed that sometimes when i start my car it takes longer to fire up, it cranks longer. after it starts it runs fine but it never used to take this long to fire up. i dunno if its my battery or sumptin with my car not getting enough fuel psi.
please help thanks.
please help thanks.
RE: Starting Problem HELP!!
Try turning the key to on and waiting for the feul pump to turn off then see if it still takes as long. If it's a pressure problem it would make sense that letting it build up a little would help. If this doesn't help I'd start looking elsewhere, unless someone else knows something more specific.
KEM Motorworks
08-14-2015 10:13 PM
