overheating then runs fine
06-12-2006, 11:33 PM
I drove my car about 5 miles and the temp guage just shot to hot, but right below the redline. I pulled over and took the radiator cap off and it lost some water. I kept filling it with water while it was running until it wouldnt take anymore. After I did this it ran fine...not hot at all. Does this sound like a faulty thermostat? Like it is sticking then when it opens it sucks the water and the motors already so hot the water burns up? Should I get a cooler thermo?
06-12-2006, 11:58 PM
RE: overheating then runs fine
yea it sounds like a sticking thermostat try putting a 180 part #3358 at oreillys ive had no prob
06-13-2006, 12:41 AM
alright...should i go lower than 180? like 160 or 165?
06-13-2006, 12:47 AM
i wouldnt unless ur running a power adder then the cooler the better mine stays at 190 in traffic with it 100 outside and it runs great
06-13-2006, 12:48 AM
oh yea also check your radiator cap it could messed up too
06-13-2006, 12:49 AM
id check the thermo first since its cheap, also, check and see if youre heat sending unit is bad if the thermo dont fix it
06-13-2006, 01:13 AM
yea but if its losing water i shouldnt have to worry about the sending unit right? Or should i check that anyways?
06-13-2006, 01:17 AM
well, prolly not, but its such an easy check. if its going bad, and you unplug it, the fan will kick on. but if youre losing water, you may have a leak somewhere, any smell of antifreeze or signs of leaking?
06-13-2006, 09:41 PM
No signs of external leaking. I let it run today until the thermostat opened and then drove it instead of just jumping right in it and it ran fine.
06-14-2006, 08:54 PM
ok... i think there some leaking...after i parked and turned off my car today i heard what sounded like water dripping into a sink full of water coming from the exhaust. i hope i dont have a cracked head. Does it sound like it from this and the car losing water?
Nick Oliver
10-17-2018 04:22 AM
2007StangV6
01-28-2016 06:09 PM
StalkerGT
09-25-2015 02:41 PM
Mobiusone stang
09-07-2015 08:46 PM
Emblazoned
09-03-2015 10:45 PM
