Trouble when going around a right curve
When going around a sharp right curve. The steering wheel moves to the right even more back and forth. Like the wheel wants to turn to the right more but then moves back to where i'm holding it and a little more to the right and back again.
Need help
Joey
Need help
Joey
RE: Trouble when going around a right curve
i had someone look at them and he said they were fine i asked a front end guy and he counldn't think what could be causing it. The car drives fine goes around left curves fine but when going around right curves it does it
sloppy control arm bushings on that side would allow a little fore/aft movement, possibly causing that problem. i've heard this is particularly a problem if you have coil-overs (less preload on the arm+bushings). worth a look at least
ORIGINAL: 87 STANG
Need help
Joey
Need help
Joey
Hey twisted that is exactly what is happening to my car, but only with right turns. I thought with the foxes there is not to much an alignment can do. How long have you had your car and has it cause any problems with tire wear
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
