What goes into an engine rebuild? - MustangForums.com
Old 06-14-2006, 02:05 AM   #1
VigCS
Default What goes into an engine rebuild?
When I get a Fox I plan on doing an engine rebuild later in the summer. I'll have ~$1500 to spend...but in general, what goes into an engine rebuild?
VigCS is offline   Reply With Quote
Old 06-14-2006, 02:27 AM   #2
Twisted
Default RE: What goes into an engine rebuild?
Never built a car motor before, but as for bike motors, they are considered "fresh" when the following is done:
Piston rings or pistons and rings
Cylinder hone or bore
valve seals
valve guides (if sloppy)
valve lapping (edit)
timing chain (edit)
crankshaft bearings
gaskets
If I'm forgetting something, I'll add it as soon as I remember.
Oh yeah, we used to clean and then lap valves in order to restore a fresh valve seal. This was done often. Less often, on some motors, valves had to be replaced. This was mostly due to carbs being set lean--people like to change their exhausts/air filters and not bother to re-jet. At any rate, this should give you a rough idea about rebuilding motors in general.
Twisted is offline   Reply With Quote
Old 06-14-2006, 02:43 AM   #3
mcfomco
Time money and most of all patience.
mcfomco is offline   Reply With Quote
Old 06-14-2006, 02:50 AM   #4
r.barn
If you really want to understand get this book. worth every penny for only $15
http://www.amazon.com/gp/product/193...v=glance&n=130
btw: i was recently quoted $1,595 for a complete drive it in and drive it away
stock engine rebuild, inlcuded 3yr/36k warranty, re-use all old hoses, accessories, sensors, ect....
r.barn is offline   Reply With Quote
Old 06-14-2006, 03:16 AM   #5
myshifter
I ♥ Acer
mass produced reman motors? Not much. Performance rebuilds? Alot
myshifter is offline   Reply With Quote
Old 06-14-2006, 03:50 AM   #6
Twisted
Quote:
ORIGINAL: r.barn
That's a great warranty. Do most stock engine rebuilds come with a warranty? Just curious.
Old 06-14-2006, 01:43 PM   #7
VigCS
Thanks guys
I dont plan on doing a performance rebuild...going to keep the stock 302 bore. I may throw a cam, headers and heads on it while the motor is out, but that's about it. How much am I looking at? I want completely driveability as it'll be my daily driver.
Old 06-14-2006, 01:54 PM   #8
88BlueGT
Well a decent set of aluminum heads will cost almost as much as a rebuild so just almost double the price right there.....
88BlueGT is offline   Reply With Quote
Old 06-14-2006, 02:04 PM   #9
r.barn
Just depends on the company, but yes most should.
Old 06-14-2006, 02:41 PM   #10
88BlueGT
^^ Thats a pretty good price. Your not in Jersey right?
OBD: The Adventure Begins (PO402 and PO401), DPFE/EGR test procedures TfcCDR V6 (1994-2004) Mustangs 1 09-14-2015 01:08 PM
Convertible Hydraulic Cylinder Mikett V6 (1994-2004) Mustangs 2 09-12-2015 11:52 PM
AODE Woes Pyrate Dave 5.0L (1979-1995) Mustang 8 09-10-2015 08:30 PM
V6 Engine Ticking Nick Oliver V6 S197 General Discussion 2 09-05-2015 11:34 AM
2004, cobra, complete, engine, motor, overhaul, rebuild, rebuilding, rebuilt, warranty
