H/C/I questions
#21
RE: H/C/I questions
Boss, if u use heads that are too large, it will kill your performance. Thats why on 5.0s usually the AFR 165s will produce more power than the 185s. Hell, i plan on running boost on my 165s until i redo my bottom end eventually, I personally think 185s are better for the 331-351 cubic inch range. AFR told me it's fine to boost a 302 with 165 heads. An engine sucking its own air is a lot different than having it rammed in, so on larger n/a engines bigger valves and ports are needed, but on smaller engines it just chokes itself...
#22
RE: H/C/I questions
yeah, it just doesnt seem to make sense to me,
if an engine has all the air it want, and then some,
it should make its optimum power availible.
but whatever lol, ill ask my dad tomorrow, havent asked him something he couldnt answer yet
im going with 185's but im also gonna be running the 9psi hellion kit.
can't wait until the end of august
#23
RE: H/C/I questions
ORIGINAL: chath_brick
Crane Cam Grind HR-220/311-2S-14
see, the thing is adder...i dont know what the hell you're talking about! i get the comment about the 185s, i wasnt going to use those anyway b/c i know they're too big. but what do you mean by 1.6 rockers? or 1.7s? see, i just dont know, those numbers are like french to me, what kind of stuff can i use with this setup? i feel like a 'tard but i just dont know what the numbers mean with any of this stuff.
ORIGINAL: OnyxCobra
Adder if that was the same cam as before then i appologize, i didnt see that the lift was for 1.7 rockers. That should barely fit (they said .530 intake was max, idk bout exhaust) but that looks like a decent cam, good amount of duration, but at 050 its still the same as the Steeda #19 I'm goin with. I hate how that site lays out their cam specs, what is the LSA?
But yea anyway... if .530 is the max you can go intake on a stock 5.0... then this bitch should fit. just make sure you get some REALLY heavy valve springs.. haha
ORIGINAL: grabbem88
i just want to know from adder if i wasted my time????
#24
RE: H/C/I questions
ORIGINAL: boss429
You need to keep consistant port velocity so the air will actually make it INTO the motor. If you look around on the internet for long enough you will find that people who run big turbo or supercharger kits usually run large port heads and box style intakes. This is due to the fact that the air is being FORCED into the motor. Port Velocity is no longer an issue in this case, however on a N/A car, too much is NOT a good thing.
Imagine taking a 10" piece of PVC pipe and laying down on the ground, and lay a 10" piece of garden hose next to it. The PVC pipe will flow a greater amount of air/liquid.. whatever.. BUT since there is so much room, the same amount of flow that would go through the garden hose can be accomplished by slowing down the flow, and that is what happens. the flow velocity is decreased and when you have a small window of time to fill a space (i.e. the cylinder) you will find that LESS air will actually make it into the cylinders, and also the fuel will be less atomized in the cylinder causing a bad burn, poor power, and a ****ty running car.
#26
RE: H/C/I questions
torque mostly, i figure (and i could be way off) if i get a pretty torquey cam combined with the hp of the afr's and the RPMII i should be sitting pretty good. but thats why i'm asking, i have no clue when it comes to cams/duration/all that stuff. i usually shift by 4500-5K when i'm banging throught he gears, so torque is my priority.
Also, I'm running 1.72's w/ my E cam on a stock bottom end w/ no problems [~.535 lift]. I went w/ the Crane valve spring kit; good to .550 lift. that's all on worked over E7's, BTW.....
#27
RE: H/C/I questions
my car aint stayin N/A for long though, so im thinking 185's.
what would a good "box style" intake be?
if thats what i should be using for a turbo?
#28
RE: H/C/I questions
ORIGINAL: gspfunk
You should research the rpm range for the parts you plan on using.... the RPM2 is similar in range to the Track heat, which is 2500-6500. If you want tq, you need to be looking at the RPM, Street Heat, SSI, or Performer. You'll also want a cam that operates on that same powerband like the E cam or TFS stage 1. You need to match your parts if you know that's how you will be driving it. If you wanted a higher revving motor, the Track Heat or RPM2 and a diff cam would be of greater benefit, but you lose low end tq.
good point...i asked about the SSI before and some people told me to stay away from it, what do you think? will it give me better torque than the RPM II?
#29
RE: H/C/I questions
I like the SSI, but have no personal experience w/ it. All the people that have it seem to like it, but it depends on your plans as far as mods go. It will probably have more low end tq, but it won't be much more.
People warn you to stay away from it b/c they either don't like how it looks, or they don't know much about it b/c it's new. It will do well in the rpm range described above (up to 5500), but not past that.
#30
RE: H/C/I questions
lol the thing that first got me interested in it was the way it looked. i might go with that then, but i'm still a little way off from doing it so i have some time to decide.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
