Explorer intake installation help
Old 06-14-2006, 07:43 PM
mimsy_5.0
mimsy_5.0's Avatar
Default Explorer intake installation help
Hey guys. I have a '91 302 right now and am in the middle of installing an explorer intake on it. I have removed the stock upper, fuel rails and injectors and am about to remove the distributor. One question about the distributor, can you manually turn the rotor to point to the #1 cylinder or do you need to crank the engine to do it? I also need help with installing the upper manifold. I noticed there are a lot more vacuum lines inderneath whiich I knjow get plugged but I am not exactly sure which ones and how to plug them. Just with rubber plugs? If you could be detailed in explaining that would be helpful, thanks alot.
mimsy_5.0 is offline
Old 06-14-2006, 07:46 PM
Bad Karma
Bad Karma's Avatar
Default RE: Explorer intake installation help
ORIGINAL: mimsy_5.0
Why do you want to point the rotor to the #1???
The important thing is to mark the collar on the Dizzy so that you don't reinstall it 180* out of spec.
You should be able to move the rotor freely once it's removed to line the gears up on the input shaft.
-Ivan
Bad Karma is offline
Old 06-14-2006, 08:40 PM
mimsy_5.0
mimsy_5.0's Avatar
I heard when you remove it to have it pointed at #1. I guess I was told wrong. So in other words as long as I put it back in the same way I took it out I am ok?
djbigskrilla
09-20-2022 01:04 AM
JonnyBlazeGT
11-03-2015 01:10 AM
SYNY5TER
09-02-2015 01:35 AM
09-01-2015 08:16 PM
Redneck1465
08-08-2015 10:39 PM
Quick Reply: Explorer intake installation help
