Fuel Pressure Problem With Video
RE: Fuel Pressure Problem With Video
ya its a stocker. im about to just go get a walbro 255. i plan on getting an S-Trim this summer anyways. you probably know how annoying this is, i cant wait till i fix it.
ORIGINAL: grabbem88
hey my amp reads low like that...two/fans...u/d's suck...i heard just change the crank pulley?
is it still a stock pump?...sounds like mine when it got hot no?
ORIGINAL: ckyguy68
cold its fine. when i prime when hot its at 30, when i start its 30 then slowly drops again.
ORIGINAL: PRO50SC
What's the f/p reading when cold and then when hot after it dies and you restart it.
ORIGINAL: grabbem88
i say pump is quirked.
this is exactly what i was thinking. combo of bad pump and warmer outside temp. and ya PRO this situation is DEFINATELY biting me in the ***!
ORIGINAL: grabbem88
LOL! YEAH!...so pump can't create vapor lock?
ORIGINAL: grabbem88
There was a weird one I ran into but again on a gm. Classic symptom. Pump failure. Repalce the pump, sent the car out everything great. Came back a few weeks later same thing. Drooped the tank to have a look and found a loose connection in the harness where it goes through the outside of the tank unit to the inside. Ended up having to rplace that as well cuz it was not a servicable part.
Long story short, although never seen it on a ford, doesn't mean it couldn't happen. Remeber, heat expands, if there is a bad connection, there will be better conductivity when it's cold ( metal shrinks)than when it's warm (metal expands).
