hesitating stroker at wot
Old 06-15-2006, 12:18 AM
  #21
91dsslx
91dsslx's Avatar
Default RE: hesitating stroker at wot
I sure im am overreacting but I just figured it whould run closer to 6.8-9. If i could get my 60' foot times down I might could reach that, but the hesitation has to go.
91dsslx is offline
  #22
Stiffclutch
Stiffclutch's Avatar
ok i noticed you have a 3k stall and you are talking about it (pardon the expression) Falling on it's face at take off, Try pre loading it to 3k where it is bumping the stall and see how she runs there. also if you wanna try to light the tires without the brakes put the peddle down and let the stall do it's thing It should rev hit 3k get the trans going and just eat the tires from there. hope this helps ( i got the stall tips from my ol' nova i had before i got the el camino sucked hard from a dead stop but if you held it up to the converter it would fly.
Stiffclutch is offline
Old 06-15-2006, 12:19 AM
  #23
grabbem88
grabbem88's Avatar
damn that must be a rocket.
grabbem88 is offline
Old 06-15-2006, 12:21 AM
  #24
silver91gt
silver91gt's Avatar
yep
silver91gt is offline
Old 06-15-2006, 12:22 AM
  #25
silver91gt
silver91gt's Avatar
they dont have any useable power below 2800rpm though. the valves are too big for a 308
Old 06-15-2006, 12:23 AM
  #26
grabbem88
grabbem88's Avatar
ok so you have same heads/intake?...rpm?..what cam? b?...tell me more?
ORIGINAL: silver91gt
yep
Old 06-15-2006, 12:24 AM
  #27
silver91gt
silver91gt's Avatar
wow those are some fast replies
  #28
91dsslx
91dsslx's Avatar
it holds good until 2800-2900 then it roles out. the best money i spent on this set up is the nitto 555. That is the only thing keeping my times down.
91dsslx is offline
Old 06-15-2006, 12:27 AM
  #29
grabbem88
grabbem88's Avatar
you two boy's and myself need to compare notes.
Old 06-15-2006, 12:28 AM
  #30
silver91gt
silver91gt's Avatar
ORIGINAL: grabbem88
yep
rpm2 intake
full msd
afr185 heads
ford motorsport b-303 cam 224 duration@0.050 and 0.510 lift with 1.7 RR's
73mm c&l maf
bbk 70mm TB
24# injectors
kirban afpr
fms aluminum driveshaft
battery in back
3g alt
ac/smog delete
bbk longtube headers with offroad x pipe and flows dumped
3.90 gears
thats all I can think of.
Quick Reply: hesitating stroker at wot
