hesitating stroker at wot
Old 06-15-2006, 12:28 AM
  #31
91dsslx
91dsslx's Avatar
Default RE: hesitating stroker at wot
hear ya
91dsslx is offline
Old 06-15-2006, 12:33 AM
  #32
91dsslx
91dsslx's Avatar
I named most of what I have, add to that is mallory ignition, strange axles, my cam is the middle tfs. The lift is 542, the heads have been "worked" alittle.
91dsslx is offline
Old 06-15-2006, 12:35 AM
  #33
grabbem88
grabbem88's Avatar
well i'll go last now[&:]....d.s.s pro bullet 306
afr 185's comp springs/milled d.s.s 1.6's
custom cam .550/.533 .229/.239 at 111.8
rpm I intake
all MSD/u'd's two electric fans
accufab 70mm
pro-m 75
tko/centerforceII/alum d/s.....strange 8.8/3.73's with 33's eaton kevlar clutches
eibach drag springs/strange struts/shocks
old *** southside upper/lowers
bbk subframes
caster/cambers
skinnies(one cracked)
L/T's bbk x-pipe/flows dumped.
there is more,but fingers sore.
grabbem88 is offline
Old 06-15-2006, 12:40 AM
  #34
91dsslx
91dsslx's Avatar
How is the eaton kevlar clutches, It is about time to rebiuld
91dsslx is offline
Old 06-15-2006, 12:41 AM
  #35
silver91gt
silver91gt's Avatar
ORIGINAL: silver91gt
ORIGINAL: grabbem88
ok so you have same heads/intake?...rpm?..what cam? b?...tell me more?
yep
rpm2 intake
full msd
afr185 heads
ford motorsport b-303 cam 224 duration@0.050 and 0.510 lift with 1.7 RR's
73mm c&l maf
bbk 70mm TB
24# injectors
kirban afpr
fms aluminum driveshaft
battery in back
3g alt
ac/smog delete
bbk longtube headers with offroad x pipe and flows dumped
3.90 gears
thats all I can think of.
moser 28 spline axles
auburn limited slip
ssbc rear disk brakes
svo front calipers
8.8 rear cover girdle
stock tranny
centerforce clutch slipping
have a dual friction waiting to go in.
just got my draglites, 15x8 back 15x5 front.
timing at 10 degrees
bbk fenderwell CAI
zex nitrous kit using the 100 shot
remembered more
eiback drag launch springs
stock upper control arms
proform lower control arms
battle boxes
lakewood 90/10 struts and 50/50 shocks
silver91gt is offline
Old 06-15-2006, 12:44 AM
  #36
silver91gt
silver91gt's Avatar
ORIGINAL: grabbem88
rpm I intake
accufab 70mm
pro-m 75
bbk subframes
caster/cambers
how does your computer act to your 111 deg lobe seperation?
Old 06-15-2006, 01:06 AM
  #37
grabbem88
grabbem88's Avatar
phuking hates it then loves....one of those love/hate things...
the kevlar eaton is awsome...no noise either.
ORIGINAL: grabbem88
rpm I intake
accufab 70mm
pro-m 75
bbk subframes
caster/cambers
Old 06-15-2006, 01:12 AM
  #38
91dsslx
91dsslx's Avatar
grabbem88 do you have brake boost problems with your cam. My brakes are a little soft.
91dsslx is offline
Old 06-15-2006, 01:14 AM
  #39
grabbem88
grabbem88's Avatar
brakes? what's that?....this cam really hurt me in that department...compared to my old comp cam
ORIGINAL: 91dsslx
Old 06-15-2006, 01:17 AM
  #40
91dsslx
91dsslx's Avatar
I hear ya. That may be may problem I am using my brakes LOL.
91dsslx is offline
Thunderball
15
11-22-2015 11:49 PM
Omgitsa88Stang
10-05-2015 07:33 AM
guitarman376
09-30-2015 05:54 PM
Brett Ludlow
09-23-2015 06:59 AM
SteelerNation82
09-16-2015 07:11 AM
Quick Reply: hesitating stroker at wot
