95 starter in 89?
Old 06-15-2006, 12:21 AM
black89gt
black89gt's Avatar
Default 95 starter in 89?
ok guys i need a new starter.
i have heard of people changing the starters in the 91 and down foxes with the 93 and up starters.
is there any modifications to be made? or is it just a bolt on kinda thing?
reason is because i have long tube headers, and it was meant for the small starter design and the starter basically just lies on the headers, and due to the heat, after a year, the starter is shot, and will not crank up when hot.
black89gt is offline
Old 06-15-2006, 01:13 AM
03BottleFedGT
03BottleFedGT's Avatar
Default RE: 95 starter in 89?
you can use the 93 and up starter but you will have to do some wiring. the 93 and up has a selonoid built on the starter witch means you have two wires instead of just one. you will need to get about 6 feet of 10 gauge wire and some ilets. then at you fender mounted selonoid move your starter main wire to the other side of the selonoid and run it to the big post on the new starter. the take the 10 gauge and run it from the otherside of the fender mount to the small post on the top of the starter mounted selonoid. the wala you save weight and your car starts better. but if your headers are that close i would also recomend a starter heat sheild
03BottleFedGT is offline
Old 06-15-2006, 02:03 AM
black89gt
black89gt's Avatar
so the main starter on the car right now you move it to the big post on the new starter?
and the new wire on the smaller part?
also, what do you mean by the fender mount? that's whats confusing me
Old 06-15-2006, 07:55 PM
03BottleFedGT
yes that is correct. the fender mount is the starter selonoid that your car has on it factory follow the positve battery cable it goes to it.
Old 06-15-2006, 08:56 PM
black89gt
black89gt's Avatar
ohhh alright thanks a million
Old 06-16-2006, 01:20 AM
03BottleFedGT
no prob
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
logan409
09-26-2015 07:43 PM
jaiidutch
09-14-2015 10:29 AM
wilsonro
4 Cylinder NA and Turbo
09-11-2015 07:13 AM
daytooday
09-01-2015 09:33 AM
Quick Reply: 95 starter in 89?
