Building a 302
Old 06-15-2006, 01:49 PM
ASUSMC
ASUSMC's Avatar
Default Building a 302
I am looking to build a strong 302 and get it bored out. Is there any one year of the 302 block that I should look to get?? Are they all about the same?? Did anyhave forged internals to start with???
ASUSMC is offline
Old 06-15-2006, 01:53 PM
88BlueGT
88BlueGT's Avatar
Default RE: Building a 302
They did not come w/ forged pistons in 93.
88BlueGT is offline
Old 06-15-2006, 02:37 PM
ASUSMC
ASUSMC's Avatar
bump
ASUSMC is offline
Old 06-15-2006, 02:41 PM
P Zero
P Zero's Avatar
85-92 all have forged pistons. The 93HO's have hypereutectic. All 302 blocks are basiaclly the same, the only difference between a HO and non HO, is the HO's have a lifter retainer, theres 2 little holes that hold this thing down. Thats it, other than from the factory most HO's had forged pistons. So no there is no "best" year for the 302 block.
-P.
P Zero is offline
Old 06-15-2006, 02:48 PM
ASUSMC
ASUSMC's Avatar
So definitely buy a HO block???? Where would those two little holes be if I were to look for them
ASUSMC is offline
Old 06-15-2006, 04:32 PM
ASUSMC
ASUSMC's Avatar
What would be the best bore???
ASUSMC is offline
Old 06-15-2006, 05:20 PM
350kmileFord
350kmileFord's Avatar
91 and 92 year engines were supposedly the best. They had a strong block, forged pistons (93 had cast)
The 91 and 92 also supposedly had other heavy duty parts.
350kmileFord is offline
Old 06-15-2006, 05:21 PM
88BlueGT
88BlueGT's Avatar
I have never heard of the 91's and 92's having more "heavy duty" parts. I'm almost positive that the blocks are the same. I guess I could be wrong though
88BlueGT is offline
Old 06-15-2006, 05:25 PM
ASUSMC
ASUSMC's Avatar
Best bore for this. Me and my roommate are building this for a streetrod, either new edge or fox (probably new edge) with forced induction. We are looking to run about 20 psi.
ASUSMC is offline
Old 06-15-2006, 07:06 PM
NoviBlown331
NoviBlown331's Avatar
20 PSI, dude, you got to get either a R302 or a Dart Block there is no way a stock block will handle 20psi, dont even bother to waste your time on DSS level 10 or 20 blocks cause there still stock blocks. You need to get a 4 bolt main.
NoviBlown331 is offline
Quick Reply: Building a 302
