free/cheep mods
Old 06-18-2006, 01:25 AM
SpooledupRacing
SpooledupRacing's Avatar
Default free/cheep mods
OK on my 87 5.0 HO I picked up today I took it to the track and ran a 15.1 @ 93.33
from what I can tell the car is all stock except for a set or stock looking headers (very thin tube headers)
what can I do that is free/cheep to gain some hp's
I plan on doing:
full strait 2.5" or 3" duel exhaust with a pair of glass packs (prolly keeping the headers on it)
plug wires (8mm or larger)
new plugs
new cap and rotor
msd coil
change oil prolly using 20W50 either castrol or mobil (not synthetic)
change fuel filter (if external)
change out my diff and trans fluid (5spd) (what fluids do u recomend for these)
anywho just wondering if there is a air intake and filter kit u recomend so I can rid myself of the stock air box (or has that shown to be a good box?)
any more info would be great i have roughly 200-300 to spend this week on it and I want to do the best things first (however the most for the money)
Dave
SpooledupRacing is offline
Old 06-18-2006, 01:38 AM
ZachW04Stang
ZachW04Stang's Avatar
Default RE: free/cheep mods
If you save up a couple hundred more you could get a trick flow track heat manifold, I think it cost $460 and would definitly be better then just doing a cold air and full exhuast which is way more expesive. A tune up may help, don't know how well the previous owner maintained the car. If you bump the timing up to 14* base timing and run 93 octane gas you will gane a couple of hp.
ZachW04Stang is offline
Old 06-18-2006, 01:50 AM
SpooledupRacing
thats 14* after TDC
I am using 93 octane, gonna give it a tuen up regardless, and now what do u think is an open cone filter gonna be better then the stock air box?
Dave
Old 06-18-2006, 01:51 AM
Goosepoop302
Goosepoop302's Avatar
i thought it was 14 BTDC
Goosepoop302 is offline
Old 06-18-2006, 01:58 AM
SpooledupRacing
thats why I am asking.
Old 06-18-2006, 05:36 AM
TRL12087
TRL12087's Avatar
how exactly do u tell when it is at TDC, my timing is off and i dont have a timing light, im trying to get my timins set as best i can
TRL12087 is offline
Old 06-18-2006, 07:54 AM
detroit50
detroit50's Avatar
What does it matter if its TDC or BTDC? Im just askin because I thought u could just loosen the distributor and rotate it to whatever degree (10-14) and u would be fine.
detroit50 is offline
Old 06-18-2006, 08:04 AM
collincastaneda
collincastaneda's Avatar
It's called "advanced" timing for a reason fellers. Advance = forward, and retard = back. You do the math.
collincastaneda is offline
Old 06-18-2006, 08:08 AM
detroit50
detroit50's Avatar
Ok so whats the relation of Advanced with BTDC or TDC?
Old 06-18-2006, 08:44 AM
SpooledupRacing
if u are advancing your timing it is ATDC retard is BTDC..
if u hit the timing light u will see a 0 the hash markes before the 0 and hash markes after the 0... 0 = TDC thus is u want BTDC (before top dead center) or ADTC (after top dead center)
Dave
Quick Reply: free/cheep mods
