what would it take to get to 325 at the wheels?
Old 06-23-2006, 01:57 AM
kickasp
kickasp's Avatar
Default what would it take to get to 325 at the wheels?
what mods would it take to get to 325rwhp without a turbo/super charger ? any idea how much $$$?
kickasp is offline
Old 06-23-2006, 02:00 AM
duslep
duslep's Avatar
Default RE: what would it take to get to 325 at the wheels?
im wonderin the same thing because here are my upgrades i just purchased and was wondering how much horse theyd put out.
1. BBK 75MM THROTTLE BODY
2. BBK 75MM EGR PLATE
3. BBK Shorty Headers
4. BBK Off road H-pipe with no cats
5. BBK FUEL PUMP 255 LITERS/HOUR
6. Ford racing 30 lb injectors
7. BBK SSI Intake (honed out)
8. Ford Racing Aluminum Driveshaft
9. A/C eliminator
10. Smog pump eliminator
11. Ford Racing 3.90 gears
12. MSD 6Al Ignition Kit
13. MSD Blaster 2 Coil
14. MSD 8.5 MM wires
15. NGK spark plugs
16. MSD Distributor
17. King Cobra clutch
18. Rebuilt t-5 tranny world class
19. Pro 5.0 shifter
20. Steeda clutch cable
21. Hypereutectic Flat Top .30 pistons
22. lunati camshaft with Duration 284/292, Lift .500/.510
23. Hi flo oil pump
Block is bored .30 over and has stock crank
Heads are also ported, buit stock
duslep is offline
Old 06-23-2006, 02:01 AM
Black Snake
Black Snake's Avatar
Nitrous?
Best way to make 300+ hp is a Head, Cam, Intake combo. But even with that your going to need more, nitrous is the safest and easiest way to get that much power
Black Snake is offline
Old 06-23-2006, 02:04 AM
randy78045
randy78045's Avatar
ORIGINAL: duslep
9. A/C eliminator
15. NGK spark plugs
16. MSD Distributor
19. Pro 5.0 shifter
23. Hi flo oil pump
Every one has preferences, but add this all up an you could put a supercharger on your car an call it a day... the mods will never end, trust me...
randy78045 is offline
FullAuto
FullAuto's Avatar
On a stock shortblock, I'd say AFR 165s, FTI cam, Edelbrock Performer/RPM, 5 speed. It would also help if the a/c, power steering and stock fan were gone. On a 10:1 306, it would be a little easier.
FullAuto is offline
Old 06-23-2006, 02:11 AM
stanglx2002
stanglx2002's Avatar
ORIGINAL: duslep
9. A/C eliminator
15. NGK spark plugs
16. MSD Distributor
19. Pro 5.0 shifter
23. Hi flo oil pump
DYNO THE DA** THING!!!!!!!!!!
stanglx2002 is offline
Old 06-23-2006, 02:14 AM
FullAuto
FullAuto's Avatar
ORIGINAL: duslep
Are you sure you just bought all of this?
FullAuto is offline
Old 06-23-2006, 02:16 AM
Black Snake
Bout to say the same thing. I dont think ford racing makes the 3.90 gear yet hehe.
Old 06-23-2006, 02:20 AM
FullAuto
FullAuto's Avatar
I think Motive is the common 3.90 gear.
FullAuto is offline
Old 06-23-2006, 02:37 AM
kickasp
kickasp's Avatar
well id prefer it be all motor, i cant afford to refill after every light lol.
with a good head, cam, intake, headers, full exhaust, and tb spacer you think it would be close to 300rwhp?
kickasp is offline
Quick Reply: what would it take to get to 325 at the wheels?
