How fast are you??
#61
RE: How fast are you??
ORIGINAL: silver91gt
here goes
engine:
308 around 9.5 comp ratio with hyperutectic pistons
AFR 185 heads 62cc
edelbrock rpm2 intake
bbk fenderwell CAI
bbk 70mm TB
73mm C&L MAF
comp cams 1.7 stud rockers
ford motorsport b-303 cam
kirban AFPR
24# injectors
zex nitrous kit running the 100 shot
ac/smog deleted
griffin rad
edelbrock water pump
3 electric fans
3g alternator
msd 6a
msd distributor
msd blaster tfi coil
ford racing plug wires
suspension/drivetrain:
eiback drag launch springs
proform lower control arms
stock uppers
ford motorsport aluminum driveshaft
motive 3.90 gears
28 spline auburn limited slip
moser 28 spline axles
rear cover girdle
rear disk brake conversion
svo front calipers
steeda tri-ax shifter
thats about it.
on motor I ran a best of 13.2@106
and with the 100 shot a 12.3@111
that is not driving it hard, I am waiting till I get my draglites and 275 drag radials on there.
here goes
engine:
AFR 185 heads 62cc
bbk fenderwell CAI
bbk 70mm TB
73mm C&L MAF
kirban AFPR
24# injectors
ac/smog deleted
griffin rad
3 electric fans
3g alternator
msd 6a
msd distributor
stock uppers
motive 3.90 gears
rear cover girdle
svo front calipers
thats about it.
09-16-2015 07:53 PM
