Weird noise at shift. Sounds like a belt.
Old 06-24-2006, 06:28 PM
Prometheus
Prometheus's Avatar
Default Weird noise at shift. Sounds like a belt.
Hi, I have a 1990 GT. It has an automatic transmission and is all stock. At certain ambiant temperatures, when the car shifts from 1st to 2nd or 2nd to 3rd, there is a weird sound. Sounnd very simular to a slipping belt. I have had my tranny checked and new filters and fluid put in. I was told the tranny was in good shape. My belt has some wear (slight surface cracking), but it doesn't look too bad to me. I can feel a vibration in the pedal when the weird noise happens. It only happens when the car is a bit cold and the outside temperature is around 60ish degrees. Any ideas any one? Thanks!
Prometheus is offline
Old 06-24-2006, 06:33 PM
ZachW04Stang
ZachW04Stang's Avatar
Default RE: Weird noise at shift. Sounds like a belt.
Obviously change the belt first and see what happens. If the belt is cracking that means its dryed out and it could be slipping.
ZachW04Stang is offline
AmericanMuscle4.6GT
11-10-2015 02:06 PM
69Volunteer
09-30-2015 10:39 AM
MustangV6P
09-28-2015 11:00 PM
mungodrums
09-28-2015 10:54 PM
MasterLanMan
09-13-2015 08:21 PM
Quick Reply: Weird noise at shift. Sounds like a belt.
