Magic drainplug washers
Old 06-24-2006, 10:44 PM
Twisted
Twisted's Avatar
Default Magic drainplug washers
Probably not too interesting, but some of you remember that I am using plastic oil drainplug washers (from the dealer), and was having trouble with the rear one leaking. Well, I have since noticed a curious thing. The washers allow the rear drainplug to work itself loose in under 100 miles. On three occasions, I have tightened the rear drainplug with a good torque wrench--first to 15, then 20, then to 23 ftlbs of torque. All three times, the bolt loosened 5-7 lbs in under 100 miles, and started leaking again. It may sound crazy, but it appears to be true.
Twisted is offline
Old 06-24-2006, 11:58 PM
ZachW04Stang
ZachW04Stang's Avatar
Default RE: Magic drainplug washers
Sounds like its stripped. I run nylon washers, which is what I think you have and I have no problem with mine loosening up.
ZachW04Stang is offline
jwog666
12-27-2021 08:09 PM
Cavedawg
09-17-2015 09:51 AM
Urambo Tauro
09-07-2015 12:47 PM
SterlingStunner
5.0L V8 Technical Discussions
09-04-2015 06:28 AM
mustangfan305
08-07-2015 11:09 AM
Quick Reply: Magic drainplug washers
