Slight tick in the motor..what could it be?
the '92 GT I'm picking up later in the week has a slight tick in the motor...what could cause this? The motor runs great so I assume it's nothing serious. Motor has plenty of oil.
Any ideas? Could it be lifter tick? When you put a screw driver on the water pump and listen you can hear it.
RE: Slight tick in the motor..what could it be?
Could be a valve, lifter, or even a noisey injectors. Might be an exhaust leak that the header or a water pump going bad. Theres to many things it could be.
ORIGINAL: 2 kwik
is the oil black?
is the oil black?
