Engine trouble
Engine trouble
I have a 1994 Mustang GT, and im having trouble with the car. everytime i drive it for a little bit and turn it off and try to crank it back up, it sounds like it floods out or sumthin, it just bogs out.. i changed the coil on it and the feul filter and its still doin it.. does anybody know what the problem might be..
RE: Engine trouble
can you discribe this a little more
ORIGINAL: 1Loud5.0
RE: Engine trouble
my bad...when i try to crank it back up it idles like a 1500 rpms, then it starts havin a rough idle, whenever u try to press on the gas it makes it worse..then it finally cuts off..if i wait like 3 minutes and crank it back up it runs fine..i think it has sumthin to do with the feul pump or the injectors.
RE: Engine trouble
Run a DIY KOEO/KOER self-test, FYI....since your car is a '94...the VIP connectors to run the self-tests are behind the RH strut tower.
TfcCDR
09-14-2015 12:08 PM
09-01-2015 08:16 PM
