trick flow heads.......
Old 06-25-2006, 04:37 PM
mallory
mallory's Avatar
Default trick flow heads.......
i just stepped into the world of aluminum heads, i bought a set of trick flow heads i was wondering for you guys who have used them how do you like them...and any advice or information on them would be great...thank you..
mallory is offline
Old 06-25-2006, 04:59 PM
50mikey
50mikey's Avatar
Default RE: trick flow heads.......
hmm any advice....bolt em on already! I like mine, dont give me any issues
50mikey is offline
Old 06-25-2006, 05:04 PM
capnacee
capnacee's Avatar
I'm listening too
capnacee is offline
Old 06-25-2006, 05:13 PM
myshifter
I ♥ Acer
myshifter's Avatar
they benefit tremendously from max porting
myshifter is offline
Old 06-25-2006, 06:05 PM
mallory
mallory's Avatar
i know some serious porting would help them flow a great deal better...but that will come down the road....im just trying to find out about them as far as performance goes for being stock trick flows are they good, any bad flaws anything to that nature.....thanks again for all help
mallory is offline
Old 06-25-2006, 06:22 PM
myshifter
I ♥ Acer
myshifter's Avatar
ORIGINAL: mallory
well they are far better than a stock casting, avoid the early early ones, I would have to look at some notes but TFS had a bad run of castings that side loaded the valve, causing destruction. I blew up a 306 in 95 due to this.
Old 06-25-2006, 06:25 PM
angcobra
angcobra's Avatar
Mine work great they are supporting over 725 HP.
angcobra is offline
Old 06-25-2006, 07:30 PM
OnyxCobra
OnyxCobra's Avatar
the Twisted Wedge heads are very good.
OnyxCobra is offline
Old 06-25-2006, 07:37 PM
91dsslx
91dsslx's Avatar
Put them on as soon as possible and go out and feel the power. I love mine, but you need to have them ported and polished to get the full effect.
91dsslx is offline
Old 06-25-2006, 08:30 PM
foxontheprowl
foxontheprowl's Avatar
I got the twisted wedge heads too, I like them quite a bit, though my car does run a bit warmer than it used to and I think it might be due to the aluminum.
foxontheprowl is offline
Quick Reply: trick flow heads.......
