Need help with jerking
Old 07-21-2006, 02:37 PM
Leeiswho2b
Leeiswho2b's Avatar
Default Need help with jerking
I just bought a 88 LX w/ T-tops. IT has many mods done to it, but will try to name as many as I can. 302 bored .30 over, Trick Flow intake, Eldebrock aluminum heads, 24 lb injectors, mallory oil pump, 4.6 roller rockers, B303 cam, BBK headers, MSD ignition, MSD distributor, Pete Jackson gear drive, underdrive pulleys, Cervini Mach 1 functioning Ram air induction, 75mm throttle body, electric fan, 9 month old tremec tranny, ford racing clutch, BBK short throw shifter, 3.73 gears, off road H-pipe, 40 series flows, no cats, and more that I am forgetting. Anyways, it won't hardly idle when cold unless I control the throttle, and the car will jerk while driving until you get above 3k rpms. If you are in 1st and just trying to just move the car at low speed (under 10mph) it keeps jerking constantly, but doesn't feel like a cam lope to me. It runs like a scolded dog otherwise. Just don't no where to start looking.
Leeiswho2b is offline
Old 07-21-2006, 02:41 PM
r.barn
r.barn's Avatar
Default RE: Need help with jerking
sounds like your clutch.
high performance clutches are known to do that.
part of the give and take of having a high horsepower "street" car.
dont know what the fix is
r.barn is offline
Old 07-21-2006, 02:55 PM
fastfox86
fastfox86's Avatar
ORIGINAL: r.barn
+1
fastfox86 is offline
Old 07-21-2006, 02:57 PM
LTnone
LTnone's Avatar
Check your MAF- if that's not working properly the engine will run rough. Also your ignition module. Good luck
LTnone is offline
Black95MustangGT
Black95MustangGT's Avatar
yeah its the clutch, even stock mustangs will sometimes jerk with the stock clutch, mine does unless i push on the gas a little then once i let off it jerks.
Black95MustangGT is offline
Old 07-21-2006, 03:01 PM
red85gt
red85gt's Avatar
My 85 does this pretty bad too. So did my 86, so does my 79 landcruiser, and even my 2005 tacoma D/D does it every now and then in traffic.
red85gt is offline
Old 07-21-2006, 03:06 PM
BascoSauce
BascoSauce's Avatar
..help with jerking..hmmmm??
Johnson and johnson lotion??
BascoSauce is offline
Old 07-21-2006, 03:10 PM
88stangaruu
88stangaruu's Avatar
well first you need to lube up really nice...get you some nice nudie movies.....
nah j/k
i agree....+1 for clutch...
88stangaruu is offline
Old 07-21-2006, 03:11 PM
Leeiswho2b
Leeiswho2b's Avatar
Shampoo IMO......lmao! Was just wandering if both idle and jerking is both related to the same problem.
Old 07-21-2006, 03:16 PM
Derf00
Gentleman's Relish
Derf00's Avatar
You said you just bought the car, was it a DD or a track car?
If its a track car, the clutch is probably in need of replacment and the cam in the car is way to aggressive for DD which is what gives you the lopey idle. Find out what kind of cam or the durations of the cam to get a better idea.
Derf00 is offline
Quick Reply: Need help with jerking
