Procedure for A/C Recharge
I replaced a couple O rings in one of my a/c lines and the system still wont hold a charge. a friend of mine said I had to vacuum the system first then add the r134 a? is this true?
RE: Procedure for A/C Recharge
Ok do not take this wrong but this is something you should leave to a pro since it is obvious you do not know and neither does your friend. What year is your car and has it been converted to R134?? If not adding R134 will ruin your A/C system. For a R12 system yes you will need to pull vacuum first before being able to add R12 but if you do not have the proper gauges and know what the proper pressures should be you are risking serious damage to yourself and the A/C system
Richard
Richard
ORIGINAL: 5.0 MPG
Now maybe you can tell me what I need to do to get some cold air through my vents???
Jesse
u really need to have a vaccum pulled 28 inches of hg (mercury) its the vaccum at which water boils and evaps really should pull the vaccum for at least a good hour or more and check for a drop in vaccum if so theres a leak! then u need a proper guage to recharge
Like it was stated above, you will need to pull a vaccuum on the system to 29. Leave it in a vaccuum for 15 minutes and see if it loses any vaccuum. If it does you have a leak, if it doesnt its good to charge. At that point you can add freon after purging the line. The system might not take enough freon by itself depending on the temp. outside. If that happens put approx 1.5 lbs in and turn the AC on. Jump the low pressure switch and it should take the rest. On the guages on a fairly hot day it should be about 250 on the high side and 40ish on the low side.
thanks boys! Great info!
no wonder it wasnt holding a charge!
I have the low side on a vacuum right now, Im going to leave it there for a couple hours to be sure. If it holds can I re charge it with a can of R 134 A on just the low pressure side? Or do I need to mess with the high pressure side with something? Do I need to put the vacuum on the high side?
ORIGINAL: cioccoj
Yeah I am going to do my AC sometime this week, it hit 116 today where I live, and I worked 10hours outside... I want to get it done, except I am replacing my 3 ac lines, so maybe I don't need to do a vacuum, just gonna get an o-ring kit and replace them. Also, must I use a gauge? Seems like a lot of kits have ones without, never made sense of that.
ORIGINAL: 5.0 MPG
how do you purge the line?
ORIGINAL: cioccoj
