disopointed with torque converter!
Old 07-31-2006, 10:24 PM
blk89lx
blk89lx's Avatar
Default disopointed with torque converter!
ok im a lil disapointed. i just got my new converter put in my 89 i had it custom built from pro torque and i wanted a 3,000 but they said that would be too much for a sum what stock car so they talked me into a 2,400-2,600 stall. i paid like 425 for it plus another 400 for the install. i dont realy notice a difference that much like i thought i would really feel a big differnce. i realy dont like having another one built plus another install. what should i do? should i just get a new one?
blk89lx is offline
Old 07-31-2006, 10:48 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
Default RE: disopointed with torque converter!
1st learn how to put 1 in..400 savings which is a lil high .. 2nd some times people think it's going to be more than it is..do you have a set of gears in car? shift kit? ..and I hope a big *** trans cooler
2 kwik is offline
Old 07-31-2006, 10:52 PM
Valcore
Valcore's Avatar
get some gears if you don't have any, From what I have heard, gears and tourqe converters go hand in hand.
Valcore is offline
Old 07-31-2006, 11:10 PM
lookinforastang
I ♥ Acer
lookinforastang's Avatar
so many people get < 3000 because they fear it's too much yet everyone with a 3000 is happy and everyone who went less isnt
3000 is fine on a street car
i wouldnt even try launching at 3000 without a shift kit.. your tranny is gunna go kaboom!
lookinforastang is offline
Old 08-01-2006, 12:03 AM
hellas85stang
hellas85stang's Avatar
id say that the cam is mismatched...ya have to have the cam specs to see where ya conv needs to make power///i have a edgeracing stall 3000 and a cooler at 20,000 gvr for on a rv..and cool gr8///my stalll woke up motor....but i have 355 gears..you may have higher like 273s 0r 308s...
hellas85stang is offline
Old 08-01-2006, 12:04 AM
tinman
tinman's Avatar
OMFG, $400 for install!!!!!!!!!!!
I need to open an installation center.
Better learn to do some work your self........
You could have bought all the tools that you would have used for $400 and had beer $$$$ left-over.......
Some fast orange for cleaning up too.........
tinman is offline
Old 08-01-2006, 12:11 AM
92hatchLX
92hatchLX's Avatar
I wouldn't have let them talk you into a lower stall speed. Call them up and tell them that you are unhappy with the set up that you've got and see what they say. Also, start working on your own stuff.
92hatchLX is offline
Old 08-01-2006, 01:14 AM
luckythirteen13
luckythirteen13's Avatar
time and time again i tell people 2800rpm or higher or dont bother doing a converter........
with a mostly stock motor you probably arent even stalling THAT high because hp and torque determain the actual stall speed. it may be built for 2400 but it may be stalling at 2000-2200 because of lack of hp. get gears and hopefully you can cut a deal with the company that talked you down to such a low stall
luckythirteen13 is offline
Old 08-01-2006, 01:24 AM
92hatchLX
92hatchLX's Avatar
MMMM I can't wait till this friday! what will I be able to launch at with a footbrake with my edge 3000 rpm custom stall??? What will my flash stall be approximately???? Or am I just going to have to wait to find out??? Damnit, the anticipation is killing me!!!
Oh and BTW blk89lx, how much brake stall can you get out of it???
Old 08-01-2006, 01:25 AM
JD1969
Pro. B.S. caller outer
JD1969's Avatar
ORIGINAL: luckythirteen13
TQ is the determining factor of true stall speed, it is also worth mentoning that holding the brakes and seeing how high the tach reads before the tires spin is NOT true stall speed. If you find a way to make more torque, it will stall higher. Personally with an AOD trans and a lock up converter, there is no reason to go less than 3-3500 on a stall. I have a 4000 in my SS and it is daily driver tame, in fact I regularly drive the car over 100 miles at a time. (I don't daily drive the car simply because I have another car and black is real pain to keep clean)
JD1969 is offline
Quick Reply: disopointed with torque converter!
