Engine Idle Speed? - MustangForums.com
Old 08-02-2006, 02:14 AM   #1
1985stang
Default Engine Idle Speed?
What is the proper idle speed for an '85 with a 4 barrel. When i got it, it was running about 600 rpm, and i bumped it up to 800-900 rpm. It now seems smoother off the start, but i was just wondering what other people are running.
1985stang is offline   Reply With Quote
Old 08-02-2006, 02:32 AM   #2
88stangaruu
Default RE: Engine Idle Speed?
I got EFI, but with my cam its set at a lopey 900rpm
88stangaruu is offline   Reply With Quote
Old 08-02-2006, 02:35 AM   #3
leadfootdriver
Quote:
ORIGINAL: 88stangaruu
Mine's about 950 I guess. I have to have it that high, or it will surge 'cuz I have a 107 lobe sep, with a lower vacum. Stock computer program...
leadfootdriver is offline   Reply With Quote
Old 08-02-2006, 02:36 AM   #4
1985stang
yeah, so you think it's good that i bumped it up to 900 rpm. it's still pretty lopey, but nothing like what it was at 600 rpm. lol
Old 08-02-2006, 02:40 AM   #5
88stangaruu
cold starts are a bitch for me, even with EFI. It'll usually cut off three times before it'll run really good on a cold morning.
Old 08-02-2006, 03:14 PM   #6
Nadelle
ok ok ok stock it should be right around 750, increasing the idle speed will make the cam percivably smoother and run your engine excesories a little easyer.
so question is...is it stock? if so why run it at somthing other than what ford recomends?
Nadelle is offline   Reply With Quote
Old 08-02-2006, 03:23 PM   #7
1985stang
Quote:
ORIGINAL: Nadelle
it is bone stock in the engine department to my knowledge, and i have no idea what ford recommends. is it bad to increase the idle speed to help it run smoother?
Did a few mods this summer... drfister 2005-2014 Mustangs 9 09-04-2015 08:47 AM
timing issue 1987gt40ttopt 5.0L (1979-1995) Mustang 12 08-28-2015 11:49 PM
03 GT Chirping on Throttle msavoia23 4.6L (1996-2004 Modular) Mustang 11 08-21-2015 12:05 PM
Need Help Diagnosing Have Codes (Confused) djbigskrilla 2005-2014 Mustangs 13 08-11-2015 01:59 PM
A/C Compressor & Engine Cooling Fan Failure - Chicken or the Egg HIS S-197 4.0L V6 Technical Discussions 1 08-10-2015 06:47 PM
2006, 50, 95, auto, cam, cammed, cold, engine, gt, idle, lopey, megasquirt, mustang, rpm, speed, stock
