hp estimation for 408 with 10 psi supercharger - MustangForums.com
Sponsored by:
Sponsored by:
Old 08-24-2006, 01:05 AM   #1
92civy
Default hp estimation for 408 with 10 psi supercharger
what would a 408w stroker with a intercooled supercharger @10 psi make?
afr 205 heads, cammed, intake?.
what would the hp be approx. if set up good?
92civy is offline   Reply With Quote
Old 08-24-2006, 01:09 AM   #2
ckyguy68
Default RE: hp estimation for 408 with 10 psi supercharger
ok, for that you would want the AFR 205 heads, and you DONT want the BBK intake, ask rbarn. Randy is running a N/A 408 @ around 430rwhp, so with a blower im sure you could see 500+rwhp.
ckyguy68 is offline   Reply With Quote
Old 08-24-2006, 01:10 AM   #3
88ragtop
88ragtop's Avatar
I would say 550
88ragtop is offline   Reply With Quote
Old 08-24-2006, 01:14 AM   #4
92civy
Quote:
ORIGINAL: ckyguy68
what is the right intake for this setup?
Old 08-24-2006, 01:15 AM   #5
BlackLX
Yeah, I just saw a post from Randy has a carbed N/A 408 with AFRs and makes 430hp. What kind of numbers will 10psi give you on one? I wonder if you will need an aftermarket block.
BlackLX is offline   Reply With Quote
Old 08-24-2006, 01:15 AM   #6
aode08
depends on compression, 10 psi is high, , those heads, intake, exhaust, will make that blower happy, min 550 hp
aode08 is offline   Reply With Quote
Old 08-24-2006, 01:17 AM   #7
ZachW04Stang
In the latest issue of mm&ff they made 525hp with the trickflow box intake on a 408. I can't remember if it was supercharged or not.
ZachW04Stang is offline   Reply With Quote
Old 08-24-2006, 01:18 AM   #8
92civy
thats another thing will the 351w block hold up to say 600 ponies
Old 08-24-2006, 01:20 AM   #9
92civy
Quote:
ORIGINAL: ZachW04Stang
is that the sept issue or the aug i dont remember seeing it in aug
Old 08-24-2006, 01:22 AM   #10
mrbigshot
without knowing the rest i would say 510 at the crank or about 432 at the wheels. should be good for 11's
mrbigshot is offline   Reply With Quote
TNT, New PB TCStangerv6 Street/Strip 12 10-11-2015 05:57 PM
So who wins uedlose The Racers Bench 4 10-01-2015 08:31 PM
Hot Lap: 2015 Roush RS3 Test + Build a Supercharger! - AmericanMuscle.com AMAlexLazarus AmericanMuscle.com 0 10-01-2015 09:21 AM
10, 10psi, 205s, 408, 408w, 550, afr, carbed, ford, hp, psi, sbf408supercharger, stroker, supercharged, supercharger
