VACUUM LEAK NO BOOST
Old 08-31-2006, 11:32 AM
only90s
only90s's Avatar
Default VACUUM LEAK NO BOOST
I can hear a whistle towards the back of my motor and think I have a big vacuum leak...My boost gage reads like between 15-20 on the vacuum side when driving down the road and when I get on it....it will go back to 0.
Problem is I have a 9lb supercharger on it and it wont go past 0...could the vacuum leak cause this...the supercharger appears to be working fine...it was building 9lbs of boost last time I really got on it last week.
Thanks
only90s is offline
Old 08-31-2006, 11:36 AM
aode08
aode08's Avatar
Default RE: VACUUM LEAK NO BOOST
well when you did that intake swap, you didnt follow the bolt torque pattern for your lower and upper manifolds, so now you have a leak.
aode08 is offline
Old 08-31-2006, 01:36 PM
92hatchLX
92hatchLX's Avatar
Are you sure that your PCV system doesn't have a leak in it???
92hatchLX is offline
Old 08-31-2006, 02:09 PM
only90s
only90s's Avatar
I have checked every line I could see..and put some silicone on some as well...I even tried to tighten my upper and lower intakes and they were tight...I got 1/4 turns on two of the upper bolts that is it...
I can still hear a whistle sound around the intake so that might be it..
I am going to try the Carb Cleaner trick later today around the intake and PCV
Called Powerdyne an they were useless(it was on car when I bought it..never would have went with it)
only90s is offline
Old 08-31-2006, 02:13 PM
92hatchLX
92hatchLX's Avatar
powerdyne's aren't bad from what I've heard. I did a Powerdyne install on a 92 GT the other day and nothing really fit, but we got it to work. Sounded good and it seemed to perform good.
Old 08-31-2006, 02:31 PM
only90s
only90s's Avatar
Default RE: VACUUM LEAK BOOST GAUGE ?
This is related to my vacuum problem..
My gauge indicates about 10 on the vacuum side at idle and then drops to about 20 while driving down the road..it will then fluctuate between 10-20..until I hit the throttle and the supercharger kicks in..and then the guage stops at 0...
Could it be a faulty guage instead of the vacuum leak I am looking for..
Any help would be appreciated. Thanks
only90s is offline
jwog666
12-27-2021 08:09 PM
mrtrodonet
09-19-2020 03:12 PM
jerrytubes
10-23-2015 12:11 PM
TCStangerv6
10-11-2015 05:57 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Quick Reply: VACUUM LEAK NO BOOST
