whats good intake???
RE: whats good intake???
ORIGINAL: jays89gt
well i think im going to go with the edelbrock performer rpm 2 with a x303 cam ,70mm tb cold air induction,should the maf be bigger that the tb??
ORIGINAL: jays89gt
i want to run nitros m iam going to get a 255gph fuel pump is that good?
ORIGINAL: jays89gt
i think i have 2 change injectors with a bigger maf was going to get 24lb injectors should that be ok??
ORIGINAL: jays89gt
iam going to order a maf calbrated to the 24lb injectors .
ORIGINAL: jays89gt
do i need to get bigger fuel rails??
ORIGINAL: jays89gt
also iam going to get some underdrive pulleys.
what kind of cam would you recomend?? and do i need heads to use the rpm2 intake i was not going to do heads yet down the road i will and if i need heads with that intake what intake do youn feel would be good without heads ??? and how do i get maf programed 4 24lb injectors?? kinda new to mustangs and want to do it the right way thanks 4 advise
ORIGINAL: jays89gt
Compared to the X cam, it has the same intake duration and cam lift, however has a longer exhaust duration and higher exhaust lift. This will drastically increase the amount of exhaust the engine can expel after combustion. remember that with stock and aftermarket heads on SBF motors, the exhaust valve is smaller, so opening it further and opening it longer will allow you to get more flow out of it.
ORIGINAL: jays89gtdo i need heads to use the rpm2 intake i was not going to do heads yet down the road i will and if i need heads with that intake what intake do youn feel would be good without heads ???
ORIGINAL: jays89gtand
ORIGINAL: jays89gt
The reason i say this is because as you learn more, you will have more questions.... the answers are out there, so search.... and if you still have questions... feel free to ask
http://www.mustang50magazine.com/tec...438/index.html
check this out
edit: and is there a reason why you don't want the MAF calibrated?
check this out
can i just use my stock heads and get them ported? or what else should i have done to them my buddy owns a machine shop and he does that stuff every day was wondering if i can go that route?
thanks 4 all the advise and help
dont want to do it the half *** way!
You can go that route but porting stock heads is a waste of time IMO.... maybe if your friend offers to do they really cheap and you are on a budget. But dont expect to flow big numbers with the stockers. IMO, if your spending all this morning all over the rest of your engine dont skimp out on the most important part Just my opinion....
