how to do a compression t
i want to do a compression test on my '88 mustang gt. my dad said you do it differently on EFI cars than on carburated cars. can anyone tell me this method, as we only know the carburated way. thanx.</P>
what i do is take the coil wire off the distributor but leave it on the coil and put the distributor end somewhere where it won't arc. Then i just put the compression tester ina cylinder and crank the motor over 3 times. I've never done anything about the fuel system. I've done it a few times and my car always starts. It's definetely rich at first but it cleans itself out quick
pull the relay , washing your wall down with gas does not do well with tryin tosimulate what actually goes on in there ,and the coil too . crack the throttle wide open , and have all the plugs out . also do it while its still warm , (ring end gaps), do a dry one and then one with a squirt or oil to see if there is a huge difference in the quality of your ring seal. good luck
