What should my Fuel Pressure be???
RE: What should my Fuel Pressure be???
mine always went down when I put the vacume line back on. you might have a vac leak. it seems as somethings off if it stays at 39, but, if it runs good, and you don't find a leak in your vac, then i'd say you're 'a ok'
Nah, it might have something to do with my altitude, my house is at like 5500+ feet, I'm sure that I don't have a vacuum leak, no idle problems, no hanging idle or bouncing idle. I guess that's just how it is, every car is different.
Conclusion:
I won't **** with it.
Conclusion:
yeah, all cars are different. mines a bi%ch to do mods to sometimes. She acts like she doesn't want them or something. always being a pain in the a$$. hehe.
ORIGINAL: XSRACINGGT
Your fuel pressure should be 39-42 psi with the vacume line OFF, then at idle, when you put the vacume line back on, it should drop to around 35 psi. the injectors are designed to operate at 39-42 psi. if you run it less, you may lean out your car at wot. if you make it more, you might make it run rich, which is beter than running lean, but you still lose power either way. stay around 40 and you'll be good.
mrappe
09-26-2015 10:16 AM
