Wet Floor
RE: Wet Floor
ORIGINAL: nseoi
if its not that it might be the condensation drain, check to see if thats clogged, happened to my old passat
that drain gets clogged because of leaves and debris.
My AC has been a 10 yr 'chase' to find freon gas leaks. When my heater core started leaking, I replaced it. when I had the dash and heater box out, I also replaced the evaporator core to eliminate it as a source of slow freon leaks. The final fix was replacing the black o-rings with green ones for R134A.
Now about your water leak, the grommet where the A/C water drain is (between the Heater box and the firewall) has a "lip" that has to be pushed through the firewall hole. I was working alone and the "lip" ended up pressed up against the firewall from the inside. Once I got the A/C working well, the water dripping out of the drain went mostly inside the car vs dripping on the ground. I had a lake in the passenger side floor pan during a long trip out west. Not wanting to pull the heater box out to get the "lip" pulled through, I put on a brass 1/4" brass elbow into the drain hole. Put a little teflon tape on the threaded side and installed a hose on the ribbed end (set up for a hose.) Routed the hose down and tied it to tie banded it to the frame on the pass side. No more water leak, good A/C and good heat. Enjoy!!
Last edited by Mallonpaulj; 11-12-2013 at 12:10 PM. Reason: Your website does not like the word "******" ????
ccdguy
09-19-2015 05:20 PM
